Bing vs. Dellorto on Puch.
† CH∆D † /
I have a stock 75 Maxi. Im getting learned up on what components work well together when tuning. Ive scanned through treats, & notice that Bing dont have very many different sized carbs? I think the stock is a Bing 15mm. What is my best bet for a new carb if I go with a 65cc kit.
What even is the 15mm referring too? What part of the carb is that measurement?
Im also curious on idle jets & running jets? As far as I can see my Bing has just one jet.
Thanks you kind knowledgeable folk. I will share the info on to anyone whom asketh.
Re: Bing vs. Dellorto on Puch.
i'm pretty sure stock bing on a 2HP is 14MM, and the 15MM was an upgrade for those who had smaller carbs that that, like 12MM.
correct me if i'm wrong...
Most stock puch bing carbs are either 12mm or 14mm. That dimension is the diameter of the 'throat' or venturi of the carburetor.
Moped bing carburetors only have one main jet, and a needle to adjust mixture. They also have an idle speed screw but that's about it. No choke/starter jet, and no idle jet.
15mm bings are aftermarket parts designed to improve performance by allowing you to move more fuel through your engine. They work best when combined with an expansion chamber exhaust.
A 19mm Dellorto PHBG will give the best performance, but is also harder to tune. You could probably find a 16 or 17 PHBG if you are worried about "over carbing" but I don't think that is a big deal. If you want easier and cheaper you can make do with a 15/16 Dellorto or 15 Bing on a small kit.
Motobee Goode /
If you are going to run the Mk65, 19mm PHBG would be your best bet. That said, it might be a good idea to practice tuning your stock bing before you take the plunge....its not hard to learn, but takes patience.
† CH∆D † /
To tune a carb, beyond the idle screw? What else is tuneable? I found the Dellorto on treats, noticed there is different choke options.
Pull// which is the bing style?
Lever// like the tomos dellorto?
Cable//which would lead up to the handle bars?
What does PHGB stand for? I like the suicide pull choke, which would lead to a cable choke?
Is the intake a big deal? Thats the part from carb to engine..cha?
Ill end up with a mellow kit that keeps me on the road with low maintenance. For real the tires on the maxi are so small I dont wanna go tooo fast.
Keep the info coming if your down.
Thanks!
† CH∆D † /
AS/DS/CS models whats that all about? Hose mount/clamp style?
† CH∆D † /
It seems Ive looped a fair crowd, so Ill ask too many questions. (Im basically the only moped shredder in my town, so here is where I learn) When it comes to kits, I see metrakit as one of the better? Ive seen polini around alot too. Whats my best bet for a decent kit?
I prefer kits with reeds. In my opinion, the Polini is easier to tune. I blew up a polini, went to a metra, and it has been a long windy road to disappointment since. Going back to polini.
The polini vs metra argument is one of the oldest in MA history.
Griffin Applicable /
what pipe do you have now? with the stock cylinder, a decent pipe and the 15 bing you should be able to get good speed while staying reliable. if you're not satisfied then, jump to the kit and carb
my 2 cents...
never worked with the metra65, put together a few polini Puchs and they are insane. extremely intricate porting.
15 bing, and well maintained for air leaks, exhaust leaks, proper jetting, and a good break in period seem like a plenty reliable kit, pick and chose the pipe carefully, could turn your stocker in a 50+ bike easy.
~SABAT!
Ok so my 2 cents on this. Bing is easier to tune less to mess with etc... Dellorto you have a lot you can tune tweak and mess with. So if your looking to go as fast as you can go with a dellorto. If you just wanna ride and aren't worried about racing anyone stay with the bing. The SHA carbs are single jet carbs like the Bings they're just cheaper to buy. The PHBG and SHA is just the model of carb. The AS/DS/CS/etc... if I remember right is how the carb attaches to the intake (that piece the goes from the carb to the engine). Hose mount means theres a hose that attaches the carb to the intake clamp means the carb its self clamps onto the intake. The intake is a small deal. No point in putting a 20mm carb on a 12mm intake as you can only flow 12mm worth of fuel and air. So intake should be of equal or greater size than the intake withing reason. If the intake is too big you're not gonna be able to mount the carb on the intake. Pull choke means theres a nob you pull on to set the choke lever means theres a lever you push on and cable means you can attach the other end of the cable to what ever you want. If you look in the wiki theres a ton of info and also a step by step guide on how to tune these carbs. As you do it more you'll get better at it. Also the Polinis are fast..... very fast. The metra's are alot more forgiving and can be decently quick. Soft seized my metra 65 twice thing still runs like a top.
I've been tuning with both Dellorto SHA and a Bing on a 70 TCCD. My 5/8' drilled Bing delivers a much better low-end throttle response than the 16 Dell, like WAY better.
It's all about the carb needle settings that a SHA can't even touch. I'm upgrading to a Dell 19 PHBG eventually, never liked the SHA.
† CH∆D † /
Turns out I do have a 14mm. Its totally stock. Your saying with my stock bike a 15mm bing & a good pipe the puch can be at 50mph? I overmixed the gas/oil at 25:1 (I swear it said that mix on the side cover) & I was getting up to 30mph. The bike has 624 original miles. Carb has a busted top gasket (bings are hard to put back together I thought. That damn top gasket) So Im going to make my own until I order a new part.
Theres a polini 64 kit with a 50 hi hi head. What components deciphers the engines cc. I dont understand the 64cc kitt with a 50cc head.
Thanks
† CH∆D † /
Shit I forgot to ask about the reed system. Whats that about?
i dont think youll get a whole lot different performance moving from a 14mm bing to a 15mm. carb size is not quite as important as other aspects...you can have a fast bike with a small carb easy.
dont overmix the gas. that will not help your performance. 50:1 is a safe starting point, adding more oil will only bog you down.
top gasket isnt even needed. i never ran one on my bing or my dellortos and it made absolutely no difference.
the engines CC is determined by the size of the bore in the cylinder. lets say you have your stock 50cc cylinder, when you look down it, its this size visually: o ...but you look down an 80cc cylinder and it will look like this: O ...horrible example but it kind of explains it.
disregard the cc rating on a head, those treats 50cc heads are just designed to be used with a 50cc engine, but since your piston never touches the head (ideally..) it makes no difference.
† CH∆D † /
I thought the top gasket was a big deal. I have a ghetto gas tank setup, & gas was pouring everywhere. I thought it was the carb but I geuss it was just the ghettonasty tank.
Thanks for the Oo cc explanation.
Werd`
Don't rob yourself of possible speed. Check and lube your drive chain, make sure your brakes arnt stuck, tires to correct PSI, maybe new petcock as well as fuel line, also with your nasty gas tank a fuel filter on your g
as line.
For my friends I suggest polini case matched 15 bing estoril pipe.. Works for sf and my friends that wanna ride and not bother with tuning
† CH∆D † /
Ok so what would be a good jumping off point if I want a kitt that is good for now, but can be tuned up easily once I gain some more mechanical knowledge?
Polini, 15 bing.. My first set up and it did me no wrong. The real learning came when I went phbg.
