Re: Mikuni Tuning (Needles)
Name Removed /
It dies before I can even open it to 1/2 throttle. Idle is perfect and can stay running at idle all day long. The main jet I installed is only a 135. Guess I'll go bigger, but don't see how it will affect fuel flow from 1/16th to 1/2 throttle.
Also, fuel flow to the carb is not an issue. Checked all the basics. While tuning it ran better and better as I raised the needle (richening the mixture). At that setting I was able to pull off the line, but not brake 15mph. Therefore, I can only conclude that my problem lies with the needle. I'll recheck some things and give it another shot with a bigger MJ. Understand that Mikuni's are usually good as is, but maybe in my case I need to switch the slide and/or needle. I'll keep you posted.
