65cc airsal kit
I have a 2006 tomos lx with an a35 engine. I want to buy a 65cc airsal kit. The website says it fits from 1993-2005. I was wondering if it would fit a 2006 since it still has the same engine.
Re: 65cc airsal kit
should fit but what else are you doing to it?
i wold also get an expainsion chamber because they actually give more gain. and i would upgrade your carb before kitting also it should fit if your motor is the same. don't forget to upjet, remove your oil injection and premix.
Re: 65cc airsal kit
Ok thank you for replying.
Re: 65cc airsal kit
ummm you really should not believe everything you are told on the Internet. stock carb airsal kit any performance pipe keep your oil injection but get motul 710 injector oil that part is very important and you will be fine. bigger carb isn't going to guaranty more speed.
Re: 65cc airsal kit
2006 to present tomos mopeds have a55 engines. ya sure its a 2006? but if you have an a35 and the kits made for that then yeah itll fit.
Re: 65cc airsal kit
▣ß@ηℊℙℐṔ∃▣ ™ /
its not the injectors, its the lines crimping from being too tight
Re: 65cc airsal kit
The last a35s came out in 2006 in the ST and LX models. The a35 has the same engine bottom and transmission as the a55 with the only difference of the larger transfer ducts in the a55 engine case. 2005 on the a35 engine cases have the same larger transfer ducts of the a55 mated to the smaller transfer ports of the a35 cylinder. Yes the Airsal a35 will fit and work and you can also take advantage of the larger transfers by bolting on the a55 Airsal kit as well.
Re: 65cc airsal kit
I have 2006 Tomos Sprint, A35 engine. This thread is full of people shooting off things they don't know to be 100% true.
Re: 65cc airsal kit
duders
kit+jcamsmikunintake+goodpipe = youre fast
Re: 65cc airsal kit
+1 on mattology's post. Airsal kit will be a great addition to your ped, def go with a good carb and a good exhaust.
Re: 65cc airsal kit
where is the best place to get an airsal kit??
Re: 65cc airsal kit
I have been considering this kit as well, looking at the treats selection appears to have the best prices, though it's a bit confusing as to which will work with A35.
Dare I ask off-topic, the best carb to go with this? I have heard about some problems with the sha 15/15, that it's better to go with a 16 instead.
Re: 65cc airsal kit
I have a parmakit for this 45mm kit new just came in..
Fred
Re: 65cc airsal kit
mikuni VM20
