Re: hpi cdi: weak spark?
Doug Ler /
sounds like you got it figured out, cookie? now for my question, mijunk, what does the black wire with white stripe off of the voltage reg. do? Did you ground it? or plug it into your butt? I was trying to kick it over without that wire going to anything, then I tried to ground it, my roomate thought he saw a spark with it grounded, then after that nothing...... I've checked the two big hpi threads, all that was really talked about was that damn lighting coil piece of shiaaat, and setting the right timing position.
