Polini V malossi pug cases?
i hear the malossi is the case of the gods, but why? better ports? volume? reed set up? what is it that makes the cheaper case rock so hard? or does it not?
Re: Polini V malossi pug cases?
I was waiting on one, but couldnt wait any longer, so I got a polini. an extra 20$ but with the treats discount code it was the same price, I hope it rocks equally as hard. Well I hope it rocks harder.
We shall see, I would love to go toe to toe with someone with the malossi case and a similar setup/weight. See what this is all about.
derbeez ryderz /
i've got polini cases that i haven't used yet, that i would be willing to take detailed pics of if someone else has good ones of a malossi.
I can tell you the intake ports are different for sure. The piston side is pretty close.. I dont know which is bigger but i have studied the pictures on treats for a couple weeks, and thats the only real difference i could see. It could be the reeds and the intake port.
and the trusted name
malossi has transfers cut for malossi cylinders... polini for polini.
the reed cages are different but probably the same volume and quality.
both would make an excellent setup.
anyone know if the 15mm malossi intake will work on the pugh malossi case?
better question: why?
