Could this Malossi h20 85cc kit fit an Puch E50 ?
https://www.malossidirect.com/index.php?main_page=product_info&cPath=5_13_106&products_id=290
me and ryan wanna meet you lets tune bikes, email ryan at ryann@mopedarmy.com
I wonder if the head studs would line up
and the stroke?
direct quote from that page's product description: _They are designed for both Minarelli and Piaggio engines._
define fit? your stroke can be a few mm off. and if you add material to the case you can redo your stud holes. so could it fit yes. could you make it fit maybe.
No, wont fit without welding an alumium plate on your casings. Cilinder studs don`t match, even as the stroke. Also the piston won`t fit on a puch-crank.
