70cc airsal 15mm bing help
Hey kids,
I'm about to install a 70cc Airsal kit and a 15mm Bing carb on my maxi, and will most likely be using a techno boss pipe. Any advice on jet size? Any advice in general?
Thanks
Re: 70cc airsal 15mm bing help
In regards to the needle jet setting, when it says 1, does that mean first notch at the top end of the needle, the end closer to the top of the carb itself?
Thanks
It should mean the notch closest to the pointy end. But who knows whether the person who typed it in did it that way. I'd start on the 2nd notch from the pointy end and go from there.
I ran this setup with a Techno Bullet pipe. I was using a mesh high flow filter and ran an 88 main jet. I would say that you should buy 84, 86, 88, 90 if you are going to use a high flow filter... Make sure you have the 15mm intake too. I had my needle 2nd from the bottom (second richest setting).
