ima try that but before i do this is my setup
im runnin a kstar 70 cc intake ported kit
21 mm intake with 21 mm dellorto phgb and a techno bullet exhaust
im thinking of making gaskets outta this cork gasket material i bought and it works really well
i thinking i might make one for my base and exhaust so when i tighten the screws on its squeezes the squish space between to make sure there are no air leaks for sure
then if its still doin it i might use this bootlegged grinder to grind down the exhaust but it might end up sideways on me thats what im worried about like i mean the carb will lay on its side horizontally
would it still be good???
other than that im still nervous to grind down the exhaust though mabey down jetting will help??
just looking for opinions to base my mods off of
