Re: Stock Moby 7 29mph added SHA15, still 29mph?
Motobee Goode /
^ that was sort of unclear. The "cover thingy" I am referring to is the spring-loaded tab (with the hole in it) that restricts the airflow when the choke cable pulls it over the air inlet in the carb. On cable choke SHAs, this never fully closes and blocks about 1/4 of the intake.
Assuming you do have a cable choke carb, here is how increase the flow (you need a dremel or equivalent)
To grind it down, engage and then release the choke lever on the handle bars. Then carefully remove the carb from the intake (no need to disconnect any cables) and pull off the air filter. You will see that the tab is blocking the air inlet. Use a sharpie to mark the corner of the tab that is blocking the inlet, and grand it down in the shape of the inlet. Done.
  Stock Moby 7 29mph added SHA15, still 29mph?Topic by: Eat A Cactus Eat A Cactus 03/31/09 12:53PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Bort Hoff Bort Hoff 03/31/09 01:02PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 03/31/09 01:05PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Jake Mesa Jake Mesa 03/31/09 01:15PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Mick Baltards Mick Baltards 03/31/09 01:21PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 03/31/09 02:18PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Jesse -B Jesse -B 04/01/09 09:51AM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: aaron_s aaron_s 03/31/09 03:04PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 03/31/09 06:22PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: VB_Pat VB_Pat 03/31/09 06:41PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Motobee Goode Motobee Goode 04/01/09 12:45PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Motobee Goode Motobee Goode 04/01/09 01:02PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Mick Baltards Mick Baltards 04/01/09 01:34PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: motobee motobee 04/01/09 02:09PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Mick Baltards Mick Baltards 04/01/09 02:12PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Newman Ryno Newman Ryno 04/01/09 03:03PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Graham Motzing Graham Motzing 04/01/09 06:23PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 04/02/09 12:20PM
