Re: Stock Moby 7 29mph added SHA15, still 29mph?
aaron_s /
the G3 will probably fit, it will just come up at an angle instead of being horizontal. you may be able to mount the rear support on the seat post, or on the gas tank. biggest problem will be replacing the skin on the inside of your leg, as it will burn off regularly. if you can cut and re-weld the header so that the pipe stays horizontal, you'll most likely have a pedal clearance issue. i'm also not sure it'll run right with a stock cylinder (unless you're porting the hell out of it, and decking the head...). the G3 is really designed for kits, and that's where it shines. i would try the simonini, if it were me.
i made the same carb swap on my seven (15.15 del sha clone), with the same results. i didn't make a custom 15mm ID intake yet, though. have you done that? if not, the carb size won't make much of a difference, as it'll be restricted at the intake. it came with a 58 jet, and bogged constantly. i'm currently running a 68 jet, and it's four stroking at 7/8 throttle. it runs great with the airbox and side covers off, though. i modified the airbox by drilling it full of holes, and i'm downjetting a little (trying a 66 first) to solve the problem. i don't think i'll see an increase in speed until i make a larger intake, though, at which point i'll need to re-tune all over....
  Stock Moby 7 29mph added SHA15, still 29mph?Topic by: Eat A Cactus Eat A Cactus 03/31/09 12:53PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Bort Hoff Bort Hoff 03/31/09 01:02PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 03/31/09 01:05PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Jake Mesa Jake Mesa 03/31/09 01:15PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Mick Baltards Mick Baltards 03/31/09 01:21PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 03/31/09 02:18PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Jesse -B Jesse -B 04/01/09 09:51AM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: aaron_s aaron_s 03/31/09 03:04PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 03/31/09 06:22PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: VB_Pat VB_Pat 03/31/09 06:41PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Motobee Goode Motobee Goode 04/01/09 12:45PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Motobee Goode Motobee Goode 04/01/09 01:02PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Mick Baltards Mick Baltards 04/01/09 01:34PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: motobee motobee 04/01/09 02:09PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Mick Baltards Mick Baltards 04/01/09 02:12PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Newman Ryno Newman Ryno 04/01/09 03:03PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Graham Motzing Graham Motzing 04/01/09 06:23PM
  Re: Stock Moby 7 29mph added SHA15, still 29mph?Re: Eat A Cactus Eat A Cactus 04/02/09 12:20PM
