mikuni flatslide TM24 crew check in: jetting
Just wondering who is using the flatslide out there, and what jets and stuff you're going with
me: alukitty malossi 4 petaled a35 tomos
altitude : dead sea level (tampa florida)
i started with the 130 jet and then went to a 140. still felt flat so i went up to a 180. it's probably too big but i don't need to seize this thing after only an hour.
still running needle in the middle spot or however it came. pilot jet it still the stock 15.
maybe i need a longer pull throttle? i'm using a streetmate throttle right now. it's getting the slide all the way out of the way.
i will jet larger and see what happens. whatever, tomorrow i'm going to powersports and buying every single jet between my 140 and 220. my aprilia RS50's getting a TM24 also, so they will share.
Re: mikuni flatslide TM24 crew check in: jetting
I think you might be able to utilize the 180 jet by setting your needle jet one notch lean. Just to see how it runs. Let me know when you can tune it tomorrow, we will get some french press and change the needle setting at the bucks.
mattology - /
yeah i'm going to pick up jets @ powersports tomrorow, and get some grips too i think. then from there we'll be able to jet. Oh and i'll get a few plugs also. probably a B7HS.
Don't the 7's run colder? I think they do, byah here is a pic
yes
