You should get a few jets that are larger than what you've got now. For example, if your carb currently has a 52 jet and runs well with that, then with the exhaust and filter, you should maybe get jets 53-57 or 58. Then when you get your jets, put in the biggest one and do a plug chop. If it's rich, then you downjet and repeat until your plug chops are nice and brown.
To find out what jet you have now, you'll have to take the carb apart and look at the number stamped into the jet. If you don't know how to do that, there's a good video here that should help.
It wouldn't be a bad idea to learn how to tune your SHA before you upgrade your carb. If you decide to upgrade your carb later, the jets you buy now will still theoretically work for a larger SHA carb (although you might not have the right size range anymore). 4 or 5 jets from treats won't set you back more than $20, so it's not like it's a huge investment.
