So, I searched and searched and couldn't find anything about if A35 sprockets and A55 sprockets are the same thing. I think they may have a different mounting hole pattern but I am not sure. All help is greatly appreciated.
Thanks
Mike
Thanks
Mike
yeah they are the same, but the highest sprocket you can put on the front is a 27tooth without doing any case modifications and the smallest one you can put on the back wheel is a 22 tooth without modification to the rear wheel hub.
