Will the Polini 19mm intake fit a City Bike?
Andrew “No-No” Strother /
http://www.treatland.tv/garelli-NOI-minarelli-V1-polini-PHBG-19mm-intake-p/minarelli-polini-19mm-intake.htm
Treats sells this (above link) and I don't wanna buy it unless I know it's gonna' fit to the frame of my City Bike.
Anybody had any success with this?
Thanks in advance.
Re: Will the Polini 19mm intake fit a City Bike?
i've never seen a city bike. but if the intake port on the cylinder isnt on such a dramatic angle that it comes close to the frame, it should be fine. U might have to file away a bit to make it fit.
Never gonna know less'n ya try.
oh, minarelli! it should, but like ^jason said, I don't know what it will do with the frame like that.
i put that same one on my city bike and had to alter it with a dremel just a bit. it gets real close to the frame. your carb has to be connected by the rubber hose. Shave down the rubber a bit and take a little off the bottom of the intake and itll work just fine. I can send you a picture of my set up later this weekend.
i have a 14mm intake that will fit
The lazers, 5 stars,... I guess these have a low.. clearance just them. You need to build a intake that .. angled.
I don't have any pictures after I cut two inches off the intake after I made.
http://img.photobucket.com/albums/v474/e-tsales/motor2Small.jpg
Frick, from the Orphans, built a plate for my City Bike that turns the intake 45 degrees. This way it clears the frame and no grinding will be necessary.
Picture please!
picture will be up in a couple hours
fo sho.
What's the word on that picture?
