Re: What about the throttle slide cutaway?
Chris if your port timing has less then 25deg's of blow down.
It can stall the transfer ports at low rpm's and run rich at low rpm's do to back flow of air/fuel mix in the carb.
A weak spark and or less then 17 deg's BTDC of spark timing will give a bog to.
  19 PHBG boggy on take off, shitty idleTopic by: Chris Rice Chris Rice 03/27/09 01:58AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Sunset Paul Sunset Paul 03/27/09 02:14AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 02:38AM
  Re: 19 PHBG boggy on take off, shitty idleRe: poo poo 03/27/09 03:32AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 10:17AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Sunset Paul Sunset Paul 03/27/09 03:40AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Tracy Tracy 03/27/09 07:01AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Jesse -B Jesse -B 03/27/09 09:24AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 10:24AM
  Re: 19 PHBG boggy on take off, shitty idleRe: paul paul 03/27/09 10:27AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 10:28AM
  Re: 19 PHBG boggy on take off, shitty idleRe: weeder weeder 03/27/09 10:34AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 10:37AM
  Re: 19 PHBG boggy on take off, shitty idleRe: mike Thomas mike Thomas 03/27/09 11:43AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 12:49PM
  Re: 19 PHBG boggy on take off, shitty idleRe: paul paul 03/27/09 12:28PM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 12:50PM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 12:51PM
  Re: 19 PHBG boggy on take off, shitty idleRe: weeder weeder 03/27/09 12:56PM
  Re: 19 PHBG boggy on take off, shitty idleRe: weeder weeder 03/27/09 12:57PM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/27/09 01:00PM
  What about the throttle slide cutaway?Re: Chris Rice Chris Rice 03/27/09 01:04PM
  Re: What about the throttle slide cutaway?Re: Shalerrr rrr Shalerrr rrr 03/27/09 01:14PM
  Re: What about the throttle slide cutaway?Re: Chris Rice Chris Rice 03/27/09 02:18PM
  Re: What about the throttle slide cutaway?Re: justin turner justin turner 03/27/09 04:28PM
  Re: What about the throttle slide cutaway?Re: Chris Rice Chris Rice 03/27/09 04:44PM
  Re: What about the throttle slide cutaway?Re: Chris Rice Chris Rice 03/27/09 04:46PM
  Re: What about the throttle slide cutaway?Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/11/10 07:12PM
  Re: What about the throttle slide cutaway?Re: bryan bryan 03/27/09 06:31PM
  Re: 19 PHBG boggy on take off, shitty idleRe: Novakarl Novakarl 03/28/09 12:38PM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/30/09 11:21AM
  Re: 19 PHBG boggy on take off, shitty idleRe: justin turner justin turner 03/28/09 12:57PM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/30/09 11:25AM
  Re: 19 PHBG boggy on take off, shitty idleRe: Chris Rice Chris Rice 03/30/09 12:34PM
  Re: 19 PHBG boggy on take off, shitty idleRe: birdsy —— birdsy —— 03/11/10 04:42PM
  Re: 19 PHBG boggy on take off, shitty idleRe: justin turner justin turner 03/11/10 05:02PM
  Re: What about the throttle slide cutaway?Re: birdsy —— birdsy —— 03/11/10 10:20PM
