19 PHBG boggy on take off, shitty idle
I've come to the conclusion that I need a smaller idle jet.
Running a light weight porting 70cc Airsal, Estoril Pipe, 19 PHBG, 22mm Bennasar intake, Malossi Red horn bendy filter, case matched on an E50.
I'm running a w7 needle on the 3rd notch (second richest). Main jet is an 86, idle jet is a 45.
The take off is boggy, twist the grip bog city. Ease on the throttle and let it creep over 1/4 and the mid range is great, pulls hard up to top speed. Top end is fine too although I might need to downjet again.
My bike is idling wierd. It revs and slows. Once I run it full throttle and come to a stop it wants to die and doesn't really surge. The surging thing is when I first start it up...
I've sprayed carb cleaner on every connection of the carb bottom end, cyclinder, head, etc... Can't find an air leak.
I had the same issue on the 2nd notch. Haven't tried all the way lean on the needle, but that scares me. I also have a w8 needle that I could use. The w8 is a leaner needle right?
I also have a 48 and 50 idle if you are thinking that I need to go richer, but I feel like it's getting too much fuel at idle...
I already ordered a 42, 40 and 38 idle jet. but I won't have it until next week.
Thanks in advance for any insight.
Chris
Re: 19 PHBG boggy on take off, shitty idle
it its only crappy on take off and idle you could try lowering the needle since you got it on the rich side and that mainly affects the lower throttle positions. I like to play with the needle, to see which way the jet should go, change it and do it again.
I thought the needle was mid range?
Drop your idle jet down. How does it act without a filter.
i'm dum
Screw the mix screw all the way in and see if it runs better, If it runs better, but not up to par, downjet(idle) more. If it runs best with the mix screw all the way out, upjet. My opinion is you're on the right track. Alot of peeps say that there bikes like really little idle jets, but my metra65'd e50 likes a 48 the best.
with my 70cc k-star I had this problem went down to a 42 idle jet. I am also running a w9 needle on the leanest setting.
I haven't tried it without an air filter...
It runs shitty with the screw out and it's still boggy with it all the way in. I was pretty sure that I was on the right track, but wanted some opinions...
Would leaning out the needle help at all? if so, is my w8 going to make for a leaner mix at idle? At this point I'm just thinking of things to do now, since I won't have my idle jets until next week...
w8 would make it run leaner.. cause its fatter
That's what I though... But does the needle effect idle at all? My mid range is sick as is.
Check your email buddy!
Nice. Is that manual posted in the wiki? If not you should post it dood. Thanks! I still wanna hear people's opinions. Shay and I agree that the idle jet is too big. I tried to tune it for about 2 hours last night at the shop.
The problem is not your needle, drop to a 42 jet (from your description of how it behaves with the mixture screw)
I am doing that for sure. I'm just wondering if the needle can lean out the idle so that it doesn't suck so bad riding it for the next week before my jets come in.
I got all that. Thanks...
My question at this point is:
Will a fatter needle lean out the idle up to 1/4 throttle at all?
Answer that and I'll buy you a beer at Whiskey Business.
no.
the needle only starts affecting the fuel metering after 1/4 throttle. its in the manual i sent you!
Page 4 Figure 2
I know that it says that, but that doesn't mean that it's not possible...
if the height of the slide (ie idle screw) effects the idle and the needle goes through the center of the slide, you would think that it would effect the idle to have a fatter needle...
The main jet has to effect idle somewhat.
What about the throttle slide cutaway?
I noticed that there are different slide available with different amount cut away... Which way is leaner on the slide? lower number or higher number on the slide?
Re: What about the throttle slide cutaway?
dont change that needle, and definitely dont lean it out. its the idle jet. most people dont mess with the slide or emulsion tubes anyway.
cool... I'll wait for smaller idle jets. Anybody got a 42 or 40 laying around?
play with your timing a bit and adjust your mixture screw.
I'm planning on not fucking with the timing... I like to keep my timing stock... The mixture screw is rich all the way in and kills the bike if it's backed out more than 2 turns...
That sounded mean. All I'm saying is that I prefer not to advance my timing to fix a jetting issue... Thanks for the ideas though. Maybe I will do it just to see what happens.
you will run much better with more timiing and you only wont it out 1/2 to 1 turn if you are stock timing if you advacne it i bet it will take that jet
If you make it run right when you take off, it could go dangerously lean at high RPM.
You need more fuel at high RPM regardless of throttle opening.
One thing that kinda helped me, is making the clutch grab later, but this isn't really a fix, it's a workaround. It did help with the bogging though.
I did not mean change the timing.
I meant to say, make sure your timing is good and your spark is proper.
I had a phbg doing the same thing and i couldnt figure out why, i had great spark, my jetting was spot on( after i ported like crazy) it just ran like shit and i couldnt figure it out..
First i changed my exhaust because with the porting the bullet just couldnt do what i ported for. Changed to a proma and bla dow! porting and exhaust and clutch has to all work together.
you have any more exhaust to t4y out>?
anything lower than a 45 just seems too small with a ported and case matched e50. your mixture screw is sensitive, you gotta do it like a 1/8 turn at a atime.
also your condenser might be worn out.
