What exhaust pipe for Honda PA50 II?
Im having trouble finding a pipe for Honda PA50 II, anyone got any links? Do i just need to install it and its ready to go, or anything else i would need to do? thanks
Re: What exhaust pipe for Honda PA50 II?
treats has this or contact motomatic about a destroyer
motomatic has two pipes for the PA50. The honda N8P which is more of a high end pipe and the destroyer which is an all around pipe. The pipe from treats is about half the motomatic, so unless you are going all out on your build get the treats pipe. It is a proma circuit clone and performs really well.
thanks for the link, do i need to weld the exhaust on? One from treatland?
No JJ, the pipe will bolt right on using the existing hardware you have on your stock exhaust.
And yeah, that is a great pipe, get it.
That little jamiraqui pipe he sells is way batter than stock too, ifn you want to only spend fifty instead of 100+. Not saying it can touch the circuit performance wise, but I thought i would throw it out there.
i have the proma circuit from treats in the mail. will i need to upjet or no?
For most mopeds I would say yes. However Honda were jetted very rich stock, so you may not need to. Once you have the pipe on do a plug chop. That should define whether you need to upjet or not.
sounds good thanks
