Re: Ring End Gap
Quick /
Not what I meant, just saying that shaving your piston rings is a good way to end up with a blown kit. Running your ped with a badly tuned carb is another way to do the same thing. So, to avoid both leave the rings nice and snug and just tune your carb well. The rings are not made of a very soft metal, they do not expand all that much unless you do something way wrong. If that happens the ring will expand in all directions and will likely get stuck in the ring groove. Im sure you have seen the pics of that. The little pin in the ring groove will stop the ring from going to far length wise and it will expand outwards causing a ... soft seize. Do it a bit worse and it will seize up permanent like.
  Ring End GapTopic by: Responsible Jon Responsible Jon 03/22/09 07:18PM
  Re: Ring End GapRe: John Joedicke John Joedicke 03/22/09 07:26PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 04:59PM
  Re: Ring End GapRe: rrk0206 rrk0206 03/22/09 07:33PM
  Re: Ring End GapRe: Jesse -B Jesse -B 03/22/09 10:33PM
  Re: Ring End GapRe: Flagrant - Flagrant - 03/22/09 08:41PM
  Re: Ring End GapRe: Josh G Josh G 03/22/09 09:54PM
  Re: Ring End GapRe: naz naz 04/08/09 12:55PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:25PM
  Re: Ring End GapRe: SABAT! andDestroy SABAT! andDestroy 03/22/09 10:00PM
  Re: Ring End GapRe: Mike Bartell Mike Bartell 03/22/09 11:45PM
  Re: Ring End GapRe: Kansas John Kansas John 04/08/09 01:19AM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 01:39AM
  Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 01:42AM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 01:43AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:19AM
  Re: Ring End GapRe: Air Bud Air Bud 04/08/09 01:51AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:30AM
  Re: Ring End GapRe: Air Bud Air Bud 04/08/09 02:47AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 03:23AM
  Re: Ring End GapRe: CtpEDsHED . CtpEDsHED . 04/08/09 08:25AM
  Re: Ring End GapRe: Mick Baltards Mick Baltards 04/08/09 10:12AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 11:53AM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 12:40PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 12:55PM
  Re: Ring End GapRe: Flagrant - Flagrant - 04/08/09 01:54PM
  Re: Ring End GapRe: Quick Quick 04/08/09 02:04PM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 02:21PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:35PM
  Re: Ring End GapRe: Quick Quick 04/08/09 02:41PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 03:30PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 03:38PM
  Re: Ring End GapRe: Flagrant - Flagrant - 04/08/09 02:57PM
  Re: Ring End GapRe: kyle the velvet quaker kyle the velvet quaker 04/08/09 06:08PM
  Re: Ring End GapRe: Silverfox Sullivan Silverfox Sullivan 04/08/09 07:08PM
  Re: Ring End GapRe: Flagrant - Flagrant - 04/08/09 11:30PM
