A larger gap takes into consideration that you are not always going to be running at optimum fuel/air ratio of the kind that would overheat the ring. Maybe a spec of something partially plugging the jet, riding into a cold air front, or fuel starvation for some reason. If you can maintain good compression and have negligable blowby whats the harm in having a .012-.014 ring gap? It may silently save you someday
