Ring End Gap
Responsible Jon /
I took a look at my Metra80 dykes ring and it looks rather large
So I measured the gap at .002" which I'm pretty sure is waaaaaaaaay to small. I did some poking around and found this formula. How do you all set your gap?
The gap should be .004" per 1.000" of bore.
Example: your cylinder has a 2.500" cylinder bore
2.5 x .004 =.010
Your ring end gap should be no smaller than .010". Gently push the ring into the cylinder bore so it is parallel and about 1" below the head surface. Use a feeler gauge to measure the end gap. Larger is OK, smaller has to be corrected. Use a flat file to remove material from the ends of the ring if needed.
  Ring End GapTopic by: Responsible Jon Responsible Jon 03/22/09 07:18PM
  Re: Ring End GapRe: John Joedicke John Joedicke 03/22/09 07:26PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 04:59PM
  Re: Ring End GapRe: rrk0206 rrk0206 03/22/09 07:33PM
  Re: Ring End GapRe: Jesse -B Jesse -B 03/22/09 10:33PM
  Re: Ring End GapRe: Flagrant - Flagrant - 03/22/09 08:41PM
  Re: Ring End GapRe: Josh G Josh G 03/22/09 09:54PM
  Re: Ring End GapRe: naz naz 04/08/09 12:55PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:25PM
  Re: Ring End GapRe: SABAT! andDestroy SABAT! andDestroy 03/22/09 10:00PM
  Re: Ring End GapRe: Mike Bartell Mike Bartell 03/22/09 11:45PM
  Re: Ring End GapRe: Kansas John Kansas John 04/08/09 01:19AM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 01:39AM
  Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 01:42AM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 01:43AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:19AM
  Re: Ring End GapRe: Air Bud Air Bud 04/08/09 01:51AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:30AM
  Re: Ring End GapRe: Air Bud Air Bud 04/08/09 02:47AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 03:23AM
  Re: Ring End GapRe: CtpEDsHED . CtpEDsHED . 04/08/09 08:25AM
  Re: Ring End GapRe: Mick Baltards Mick Baltards 04/08/09 10:12AM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 11:53AM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 12:40PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 12:55PM
  Re: Ring End GapRe: Flagrant - Flagrant - 04/08/09 01:54PM
  Re: Ring End GapRe: Quick Quick 04/08/09 02:04PM
  Re: Ring End GapRe: Responsible Jon Responsible Jon 04/08/09 02:21PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 02:35PM
  Re: Ring End GapRe: Quick Quick 04/08/09 02:41PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 03:30PM
  Re: Ring End GapRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 04/08/09 03:38PM
  Re: Ring End GapRe: Flagrant - Flagrant - 04/08/09 02:57PM
  Re: Ring End GapRe: kyle the velvet quaker kyle the velvet quaker 04/08/09 06:08PM
  Re: Ring End GapRe: Silverfox Sullivan Silverfox Sullivan 04/08/09 07:08PM
  Re: Ring End GapRe: Flagrant - Flagrant - 04/08/09 11:30PM
