cut and position puch estoril stinger ?s (pics)
So I'm going to cut and weld an estoril stinger to put on my magnum.
What is the best way to do it?
I'm going to aim for the pic attached.
The stinger is super short, how is performance different with the maxi I've pasted below?
I don't really like that look. What type of the cut estorils do the black widows rock?
Re: cut and position puch estoril stinger ?s (pics
Going for this style:
Discuss the differences:
i to would like to know, i have been thinking about doing this my self...
Pablo Puchasso /
That second would look better if the sliencer were attached directly to the chamber IMO.
holy shit i just came in my pants. where the hell did you find that pic. i love that maxi. (except for the pipe)
but yeah amazing shit right there.
doesn't the silencer add to the stinger length? That bend to the silencer is probably why that pipe has great power
i took that photo.
[pqworifjw[pergq[gjae[piveaf
4rT?242awfarfaerfaefeferfgwerfwef
t2.t]]no you didnt!!
yeah i know I took it
if you have questions about the first pic contact Devin. He built it.
Other people huge pics warning:
Yeah, but is basically any straightening going to help? so either pipe is faster than stock?
I was wondering if anyone knew what the black widows did to these pipes when they straightened the stingers?
I found two more pics:
This pipe looks sick the way it sits:
Also, Garret, did this too and said he saw a 1.5mph increase afterwords
His bike is here:
I bet chopping it makes the pipe way louder. It looks rad.
Might be fashion more than function. But I don't know for sure.
You can chop off the back cone and remove the baffle in those pipes & re-weld it back. That gives you better performance.
Pablo Puchasso /
This is one that Shaw did a while back for one of the Latebirds. Now one of our guys, Jose, has this bike. It RIPS. (ported TCCD70 on it.)
so does cutting the bend out effect performance or not
i think it might effect the powerband because it is shortening/ lengthening a certain point in the exhaust's diameter.
If you search the threads on this, many have said this slightly increases top end performance. It also looks sick and makes it so pedals clear.
how would cutting and repositioning something way back there change pedal clearance?
problem: your pedal arm hits the pipe at the expansion chamber, and your heel hits the little downspout exhaust tip.
solution: hit your pedal arm with a hammer, and straighten out the pipe
oh, ok gotcha
i would guess it's going to take away from the mid-range and add to the top end.
im in the same boat as everyone, what to do?
i was thinking strait out, super long.
~SABAT!
yeah i was thinking straingt out too, but its gonna be sticking out way past the wheel
I did this too. What I did was cut and remove the exhaust plug, cut and reroute the stinger, and make it so the header was flush with the first cone by forming a new first cone. It was sorta intense work for such a crappy pipe but it looks sweet. The torque on mine is incredible, but the top end is still not like a NateP:
no pic
Link Fail
I would say the biggest restriction on the estoril is that the header extends almost an inch into the first cone. This is the most critical junction as I understand.
Re: Link Fail
Pablo Puchasso /
that bike i posted the pic of was a top end monster. It's being rebuilt as i post this.
Re: Link Fail
my header deff sticks into th primary cone, but only like 4mm, but i could be wrong, i havent chopped the header at all.
~SABAT!
Re: Link Fail
so you actually think that the 4mm is the biggest restriction?
- Summerai - Christine L /
I just had my pipe apart and yeah I noticed that 4mm over hang inside the chamber. I should have spent the extra time to blend that in. Shit!
kyle the velvet quaker /
The restrictor is out of mine, but now its super custom, center exit with a rear exit too. It fucking rips 30mph+
thats not too fast.. but center exit. thats cool
