So I've been trying to tune my Peugeot build for a couple months, with various setbacks and not much luck. Here is the setup I'm working with:
Polini Aluminum 70cc
Simonini Circuit
Polini variator weights - middle weights
Polini return spring
Polini case
TSM high comp head
19mm PHBG clamp-on
106 main jet, 40 idle jet, w9 needle (clip I'm not sure)
Brand new condensor and points, 5 coil ignition
Panty hose filter
Here's the situation: I kept lowering the idle jet because riding around at 1/8th throttle the plug was always black. Regardless it has consistently sucked off the line. I only have 2 balls in the clutch. Once it gets up to speed a little the RPMs fly up and the thing is screaming, but not going fast. Some four stroking, probably need a lower main jet. So I'm thinking, heavier weights because its not upshifting, and downjet a little. But that doesn't explain it sucking off the line, regardless of how much throttle I give it. I was wondering too, how much advance to people with Peugeot kits use? I have it on stock advance, 1.5mm right now.
