She just wont start
A#% case matched
70cc alukit
techno estoril
16mm dellorto sha
she has plenty of spark just wont start
Re: She just wont start
getting fuel?
compression?
no major air leaks?
it has crazy compression and its definately getting gas just its smokin out the exhaust when i kick it over. no major air leaks
most likely severely overjetted. whats the plug look like? wet as crap?
maybe. i tried a 92 all the way down to an 82. what should i try?
Keep going till it sounds good and doesnt 4 stroke
it doesnt start
What are you running for an air filter?
stock air filter that comes with the sha. i dont have anything besides that. i just tried a 68 and a 75 too and still no luck
your piston is upside down
i have the "window" facing the intake
what plug u running?
what gap?
i think you need a 72 and to recheck your intake and exhaust gaskets!
Cody, somebody mentioned it before... is it getting fuel?
Check the flow from the petcock and be sure to see if the bowl is full of gas.
Did you put in a breaker points setup or a cdi?
I think you said your stuff was from your old A3... if so, be sure to check your point gap and make sure it's perfect...
J
i second the point gap...unless it's cdi. or timing, either way i was having the same problems and did everything i could think...except check the point gap...it was barely moving...reset point gap and it started right up, then i kicked myself in the face for wasting 2 days of riding.
i third the points. you can have the best spark in the world and it won't do anything if it is not using it at the right time.
