Polini for the Morni, problems with speed
Set up: M02 port matched, with a 19mm intake and carb, 4p homet.
The carb came with a 60 idel jet, and it takes a 98 main jet to run right...
Problem: It goes only 35 mph on flat! Doesnt feel like the pipe ever hits...stock header....
Anyone know how to gain more speed or if my Idle jet is too high making the rest run tooo rich...
Re: Polini for the Morni, problems with speed
sure it is. down jet your idle to like a 45 or 50. Then set your points right and blast.
oh check for air leaks cause 98 is big.
98 is massive
