Re: gilardoni cylinder scuffing
Scott /
Clearance the piston? i wouldn't recommend that as you might get piston slap and or destroy your cylinder anymore. don't forget about side forces of the piston on the cylinder. if you take off any material even a couple thousands of an inch especially on the intake or exhaust side of the piston which is where you get those forces there is a good possibility you will just aggrivate the problem and your cylinder will become out of round. check your oil seals. air leaks from your oil seals commonly cause scoring or scuffing on the exhaust side of the piston. if you had a bad oil seal combined with the increased crankcase pressure of the kit that would explain why you seized in the first place.
  gilardoni cylinder scuffingTopic by: Shalerrr rrr Shalerrr rrr 03/20/09 02:22AM
  Re: gilardoni cylinder scuffingRe: MarkRyan MarkRyan 03/20/09 02:42AM
  Re: gilardoni cylinder scuffingRe: //////////////////////////////////// //////////////////////////////////// 03/20/09 02:44AM
  Re: gilardoni cylinder scuffingRe: coco coco 03/20/09 04:15AM
  Re: gilardoni cylinder scuffingRe: Shalerrr rrr Shalerrr rrr 03/20/09 01:38PM
  Re: gilardoni cylinder scuffingRe: coco coco 03/20/09 01:58PM
  Re: gilardoni cylinder scuffingRe: MarkRyan MarkRyan 03/20/09 02:17PM
  Re: gilardoni cylinder scuffingRe: Shalerrr rrr Shalerrr rrr 03/20/09 04:43PM
  Re: gilardoni cylinder scuffingRe: Chris Rice Chris Rice 03/20/09 05:03PM
  Re: gilardoni cylinder scuffingRe: Chris Rice Chris Rice 03/20/09 05:23PM
  Re: gilardoni cylinder scuffingRe: Orphan Frick Orphan Frick 03/20/09 07:08PM
  Re: gilardoni cylinder scuffingRe: coco coco 03/20/09 07:51PM
  Re: gilardoni cylinder scuffingRe: Shalerrr rrr Shalerrr rrr 03/20/09 08:25PM
  Re: gilardoni cylinder scuffingRe: coco coco 03/20/09 09:00PM
  Re: gilardoni cylinder scuffingRe: Brandi eat a treat Brandi eat a treat 03/20/09 10:24PM
  Re: gilardoni cylinder scuffingRe: Matt Bengry Matt Bengry 03/21/09 08:17PM
  Re: gilardoni cylinder scuffingRe: Scott Scott 03/23/09 09:57AM
  Re: gilardoni cylinder scuffingRe: Shalerrr rrr Shalerrr rrr 03/21/09 08:57PM
  Re: gilardoni cylinder scuffingRe: mike park mike park 03/23/09 06:23AM
  Re: gilardoni cylinder scuffingRe: max max 03/23/09 06:28AM
  Re: gilardoni cylinder scuffingRe: maciek maciek 03/23/09 06:31AM
  Re: gilardoni cylinder scuffingRe: Shalerrr rrr Shalerrr rrr 03/23/09 06:07PM
