Air leak with new kit?
Peter Baudendistel /
I’m having some trouble with my moped and it seems you’re the one to ask. I cannot get rid of this air leak I’ve been having for the life of me. I’ve redone the gasket on the block 3 times, and each time it reappears. Maybe you can offer some input/advice that’ll help the situation.
I’m working on a 2001 Tomos TTLX with an A35. I bought a 70cc alukit from treats.
My procedure has been as follows:
1-Remove nuts
2-Remove head
3-Remove cylinder
4-Remove wrist pin retaining clips
5-Remove wrist pin
6-Remove piston
7-Scrape off old base gasket as well as possible
8-Place new base gasket in place (3 times-Once dry, Once coated in 2 stroke oil, once with silicone gasket goo)
9-Put on new piston, wrist pin, clips
10-0il new cylinder and place on.
11-Put on head
12-Put on nuts, then tighten in x pattern
Any insight would be greatly appreciated.
I'm at a lost. I don't know what it could be, other than a warped head.
