Re: more derbi content... a couple questions
duhhh
Piston port engines
cylinder inducted
stroke: 43mm
bore: 38mm
displacement: 48.7cc
compression 8.5:1
direction of rotation: counter clockwise facing magneto
Pyramid reed engines
Pyramid 3-reed valve, Crankcase mounted
stroke: 43mm
bore: 38mm
displacement: 48.6cc
compression 8.5:1
direction of rotation: counter clockwise facing magneto.
Flat reed engines
Crankcase 2-reed valve induction with triple transfer port distribution
stroke: 40mm
bore: 39.87mm
displacement: 49cc
compression: 10:1
direction of rotation: clockwise facing magneto.
Max engine RPM: 6500
