does anybody have a pic of one of these on theyre grande
i wanna see how far it sticks down
Not the same pipe, but similar:
oh thats not too bad
how is that one it looks almost the same
i wish they sold a cheaper pipe that fits it
i dont know i might end up just making a header and welding it to a jarmacol i just want somethin thats better than the shitty stock pipe
jay i have that pipe if you wanna borrow it and and see how it fits.
I have THIS version of that pipe and it fit my Grande just fine. You might have to elongate the exhaust mount on the sub-frame a little. I think the Simonnini hangs a bit lower.
yeah id like to see how it fits
il just ride down there when your gonna be around and try it there instead of borrowing it
i dont really like borrowing stuff
you know me i love going through the trails so i dont want anything that sticks down that will get distroyed
ya. you know, one of these days, somebody has to build a new vespa grande subframe with more articulation and more ground clearence, then it would be great for trail riding. and even a little more rough off road.
i wanna make a new subframe cause the original one is shit
how can they make a real heavy duty main frame then use a stamped out sheet metal sub frame
i wanna make one out of tubing and 1/16'' plate steel so it will hold up
double silencer cause two is better than one! no hate, but, that's funny looking.
yeah, it's funny looking, i admit. but it does work to keep the dB's down.
exactly! i actually don't pedal my moped anymore because it caused the subframe to twist and it cracked causing the belt and chain tension to be off and make odd noises. i got it welded up, but it might come apart again if i put too much load on it. you should make a new thread on your project. i wanna see how it goes.
that expansion chamber sits really low! i can just imagine hitting that thing on a curb when pulling into a parking lot!
actually, i haven't had trouble hitting the pipe on anything. maybe i'm just careful, but it hasn't been a problem.
it's more of a problem on my stock motobecane pipe, if anything.
yeah i dont like that at all
this is why i wanted to see a pic id end up distroying a pipe like that the way i ride
yeah im going to get the tubing and plate steel next weel and il use a bravo subframe to get all the measurments and look at to build the new heavy duty sub frame
i know il brake the shitty subframe so i might as well build one
