sachs 505/1d jetting issues. why do you 4 stroke!?
nerdzilla NoPeds :( /
i just got my g3 toppin out @ the 40+ range but when im running wide, i will 4 stroke every so often. im up jet to 62 on the infamous square bing, and i got an aftrmkt chamber n a 40 tooth rear. bored out the airbox cause it ran so good without any air restriction.... it seems to run better than it ever has but, it pop in and out of 4 strokery at top end. ill choke a it a lil to see if that helps but that hasnt seemed to do anything. help? anyone? i tried the 60 jet as well... it 4stroked hard. even with o air restriction... got the best speed on the 62.
  sachs 505/1d jetting issues. why do you 4 stroke!?Topic by: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/18/09 11:20AM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Sunset Paul Sunset Paul 03/18/09 04:53PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Erin L Erin L 03/18/09 05:12PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Erin L Erin L 03/18/09 05:19PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/19/09 01:19PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Erin L Erin L 03/19/09 02:09PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Robert Robert 03/19/09 07:20PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/19/09 09:12PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Robert Robert 03/20/09 12:25AM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/20/09 08:14PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/24/09 02:05PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: ffreddie ffreddie 03/24/09 03:51PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/25/09 07:09PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Erin L Erin L 03/25/09 07:12PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Tate Tate 03/26/09 12:28AM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 03/27/09 12:18PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Tate Tate 03/27/09 11:48PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 03/28/09 06:03PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: andrewhed andrewhed 03/28/09 09:46PM
  Re: sachs 505/1d jetting issues. why do you 4 stroRe: nerdzilla NoPeds :( nerdzilla NoPeds :( 04/03/09 09:24PM
