Re: Cylinder inducted reed valve?
Flagrant - /
You can make a piston ported cyl into a reed valve cylinder if that is your main question. You wouldn't even have to cut a window in the piston although it would be a benefit. I made one out of a stk puch cylinder. It probably would have been more successful if I hadn't raised the exhaust port a little too much. I haven't completely given up on it
