Mike, yes, understood. However, in the cylinder inducted engine, some of the fuel/air mixture is ejected back out of the intake port as the piston begins to move back down from TDC, whereas in a case inducted motor with reed valves, this does not happen, and a higher case pressure can be attained. So would it be beneficial to put reeds on a piston port cylinder?
