Very Slow take off.
I just set up my g3 with a new 505/2d bottom end matched to 65 autisa kit , 14.5 intake matched to cyl, new 15mm bing, new spark plug, Stock gearing. My problem is when i go to take off in first gear it just bogs and eventually dies. If i get a rolling start it will rev up and will go well through 1st and 2nd gear. Ive tried all sorts of jetting between 82 and 94 and all sorts of needle positions. I was thining possibly air leak? But it idles fine and plug is light black. Any help would be appreciated!
Re: Very Slow take off.
timing
Thanks, I will try to adjust the timing on the next warm day.
ya ignition timing and i would check your compression.
leaks of all sorts might make that also
Ive made some progress. I was lean in the low rpm's. I richened the needle and tried it with a high flow filter instead of no filter at all and i can actually start moving from a stop with some good pep. Another problem was i just needed to get a better feel for the bike. I guess i was letting out the clutch too fast at too low of rpms. When my 80 athena comes in it should flyyy. Im just scared of the clutch nut spinning off. EEEkk
Thanks!
wait you have a manual clutch ?
yes sir
haha! ^
yeah dude, like i told you, let that shit slip.
these guys can't even imagine how sick your bike is, you should show it off a lil.
i think once you get comfortable working the gearbox, you'll be able to outrun everyone.
have you tried down shifting to make it up a hill yet?
~SABAT!
o yea props to sabat for helping to tune in my bike!! No i havent. Ill wait for the athena 80
