This special wrench is perfect for holding the washer and allows you to tighten the nut extremely tight.I got this one from Handybikes.com. or you could make your own.
Does it make kitted Sachs clutch hold better?
How much did they charge you for it?
I don't have a kit so I can't say whether or not for sure if it solves the nut problem.I haven't had a problem with my stock engine.If you clean the threads with acetone and use some blue locktite and that wrench then it should stay on even with a kit.The wrench cost me $31.24 with shipping.I like to test on a kitted Sachs.
