Re: WTT: vespa engine case?
Maciek /
it goes around the crank in every case, that's what im trying to tell you andrew, does not matter if its case inducted or cylinder inducted, it gets sucked in to the crank case, mixurized, pressurized and turbulized, and pushed up through the transfers when they open. the simo case half is actually more like puch/peug/moby/etc.
