i think i decided the malossi would be better... the piston skirt, and piston block off half of the intake for most of the cranks duration...and the intake is being fed basically directly into just the one side/port... sketchy
and the kits piston skirt doesnt even touch the engine case on that whole half of the engine...cause the simo half is bored out for the 86cc kit. its weirrrrd.
the malossi case seems inconvenient to get to the carb though, but can use the same carb/reed setup...
is there anything else bad about the malossi cases?i guess the intake will kinda be blocked by the crank right? does anyone know what size cylinders will fit properly in them out of the box, without modification?
