Re: 50cc 50mph+ secrets?
Flagrant - /
Lowering the intake was the same as cutting the piston skirt but you could go 2 more mm on that but it may slow your low end more. With 50cc you are always dealing with a low/high end balance and that you weigh exacerbates that dilemna. I checked the performance of a bullet and a Homoet 6p back to back on a hot 50 and the 6p was only good for about 2 mph more. If you were to do a compression test what would it come to? You could shorten the Bullet at the header and or the dwell section of the pipe for higher pipe RPM action. The header on these pipes extend 2 and a quarter inches into the expansion chamber. The 6p is about 2 1/2 inches shorter than the Bullet. An auxilliary center bleed welded onto the Bullet will help. Use maybe 45 psi or more if you have good tires to compensate for your weight.
  50cc 50mph+ secrets?Topic by: dan dan 03/07/09 10:37PM
  Re: 50cc 50mph+ secrets?Re: mike Thomas mike Thomas 03/07/09 10:53PM
  Re: 50cc 50mph+ secrets?Re: Jake Mesa Jake Mesa 03/07/09 11:02PM
  Re: 50cc 50mph+ secrets?Re: west seattle west seattle 03/07/09 11:07PM
  Re: 50cc 50mph+ secrets?Re: Jake Mesa Jake Mesa 03/07/09 11:09PM
  Re: 50cc 50mph+ secrets?Re: Flagrant - Flagrant - 03/07/09 11:17PM
  Re: 50cc 50mph+ secrets?Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 03/07/09 11:23PM
  Re: 50cc 50mph+ secrets?Re: finny finny 03/07/09 11:49PM
  Re: 50cc 50mph+ secrets?Re: Dan Dan 03/07/09 11:52PM
  Re: 50cc 50mph+ secrets?Re: west seattle west seattle 03/08/09 12:31AM
  Re: 50cc 50mph+ secrets?Re: Kansas John Kansas John 03/08/09 01:23AM
  Re: 50cc 50mph+ secrets?Re: Brian Brian 03/08/09 03:39AM
  Re: 50cc 50mph+ secrets?Re: Mark Mark 03/08/09 01:45PM
  Re: 50cc 50mph+ secrets?Re: ) CuperAWESOMO ( ) CuperAWESOMO ( 03/08/09 05:35PM
  Re: 50cc 50mph+ secrets?Re: Rafter Rafter 03/08/09 05:54PM
  Re: 50cc 50mph+ secrets?Re: mollyholly mollyholly 03/08/09 06:33PM
  Re: 50cc 50mph+ secrets?Re: Andy Andy 03/08/09 07:28PM
  Re: 50cc 50mph+ secrets?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 03/08/09 10:29PM
  Re: 50cc 50mph+ secrets?Re: Jake Mesa Jake Mesa 03/08/09 10:34PM
  Re: 50cc 50mph+ secrets?Re: Thaddeus Koscuisko Thaddeus Koscuisko 03/08/09 10:42PM
  Re: 50cc 50mph+ secrets?Re: brendanM brendanM 03/09/09 02:55AM
  Re: 50cc 50mph+ secrets?Re: bryan bryan 03/09/09 03:43PM
  Re: 50cc 50mph+ secrets?Re: finny finny 03/09/09 04:06PM
  Re: 50cc 50mph+ secrets?Re: Flagrant - Flagrant - 03/09/09 04:13PM
  Re: 50cc 50mph+ secrets?Re: Graham Motzing Graham Motzing 03/09/09 04:49PM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 03/11/09 11:30AM
  Re: 50cc 50mph+ secrets?Re: finny finny 03/11/09 05:05PM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 03/11/09 05:59PM
  Re: 50cc 50mph+ secrets?Re: dan dan 03/11/09 08:28PM
  Re: 50cc 50mph+ secrets?Re: Mick Baltards Mick Baltards 03/11/09 09:22PM
  Re: 50cc 50mph+ secrets?Re: dan dan 03/11/09 10:03PM
  Re: 50cc 50mph+ secrets?Re: dan dan 03/12/09 03:10AM
  Re: 50cc 50mph+ secrets?Re: Eric Sabatino Eric Sabatino 03/12/09 03:38AM
  Re: 50cc 50mph+ secrets?Re: finny finny 03/12/09 03:42AM
  Re: 50cc 50mph+ secrets?Re: rafter rafter 03/12/09 04:50AM
  Re: 50cc 50mph+ secrets?Re: dan dan 03/12/09 04:55AM
  Re: 50cc 50mph+ secrets?Re: Tate Tate 03/12/09 11:23AM
  Re: 50cc 50mph+ secrets?Re: Nitronick Nitronick 03/12/09 11:30AM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 03/12/09 06:47PM
  Re: 50cc 50mph+ secrets?Re: andrewhed andrewhed 03/12/09 07:22PM
  Re: 50cc 50mph+ secrets?Re: Maciek Maciek 03/12/09 09:14PM
  Re: 50cc 50mph+ secrets?Re: Roberts surfboards Roberts surfboards 03/13/09 04:37AM
  Re: 50cc 50mph+ secrets?Re: Graham Motzing Graham Motzing 03/13/09 11:10AM
  Re: 50cc 50mph+ secrets?Re: black twingle black twingle 03/13/09 12:03PM
  Re: 50cc 50mph+ secrets?Re: dan dan 03/13/09 02:43PM
  Re: 50cc 50mph+ secrets?Re: paul paul 03/13/09 02:49PM
  Re: 50cc 50mph+ secrets?Re: dan dan 03/14/09 12:07AM
  Re: 50cc 50mph+ secrets?Re: bryan bryan 03/14/09 01:08PM
  Re: 50cc 50mph+ secrets?Re: Joe Joe 03/14/09 01:14PM
  Re: 50cc 50mph+ secrets?Re: Dan Dan 03/14/09 03:54PM
  Re: 50cc 50mph+ secrets?Re: Nash . Nash . 04/04/09 11:09PM
  Re: 50cc 50mph+ secrets?Re: max max 04/05/09 04:33AM
  Re: 50cc 50mph+ secrets?Re: dan dan 04/22/09 10:35PM
  Re: 50cc 50mph+ secrets?Re: Chris Squid Chris Squid 04/25/09 02:24PM
  Re: 50cc 50mph+ secrets?Re: Jimmy Stucky Jimmy Stucky 04/22/09 10:51PM
  Re: 50cc 50mph+ secrets?Re: Flagrant - Flagrant - 04/22/09 11:04PM
  Re: 50cc 50mph+ secrets?Re: naz naz 04/23/09 01:45AM
  Re: 50cc 50mph+ secrets?Re: Dan Dan 04/22/09 11:06PM
  Re: 50cc 50mph+ secrets?Re: Dan Dan 04/22/09 11:14PM
  Re: 50cc 50mph+ secrets?Re: Rich Battag Rich Battag 04/22/09 11:23PM
  Re: 50cc 50mph+ secrets?Re: Flagrant - Flagrant - 04/23/09 03:08AM
  Re: 50cc 50mph+ secrets?Re: Joe Ferlin Beard Joe Ferlin Beard 04/30/09 12:40AM
  Re: 50cc 50mph+ secrets?Re: ffreddie ffreddie 04/23/09 11:56AM
  Re: 50cc 50mph+ secrets?Re: dan dan 04/23/09 03:55PM
  Re: 50cc 50mph+ secrets?Re: small bore small bore 04/29/09 09:57AM
  Re: 50cc 50mph+ secrets?Re: ffreddie ffreddie 04/23/09 04:20PM
  Re: 50cc 50mph+ secrets?Re: A55er A55er 04/24/09 06:50PM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 04/28/09 11:27AM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 04/28/09 11:32AM
  Re: 50cc 50mph+ secrets?Re: Pablo Puchasso Pablo Puchasso 04/28/09 12:05PM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 04/30/09 11:21AM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 04/30/09 11:22AM
  Re: 50cc 50mph+ secrets?Re: mattology - mattology - 04/29/09 12:30AM
  Re: 50cc 50mph+ secrets?Re: max max 04/29/09 03:44AM
  Re: 50cc 50mph+ secrets?Re: KNOX KNOX 04/30/09 02:32PM
  Re: 50cc 50mph+ secrets?Re: Grande Deluxe Grande Deluxe 05/01/09 11:15AM
