garelli ssxl kit
looking for advice on kits for my garelli.....
Re: garelli ssxl kit
What motor, noi, vip?
▣ß@ηℊℙℐṔ∃▣ ™ /
get the polini high quality stuff
aren't all ssxl's noi?
There's only one kit available for the NOI, the 70 Polini. It's Polini, what else do you need to know?
yes I know there's other kits, but I said "available". The next most common is the Malossi, which I'm pretty sure is no longer being made, so good luck finding that one, it's radical if you can find it.
there was a malossi reed valve kit available from treats for a short time. I've seen people have impressive results with the polini kit
going with the polini as well as the polini exhaust....what about the carb action?
wait what polini exhaust? Treats currently doesn't have anything that's just bolt-and-go for Garelli...
The ol' Polini exhaust is not one I'd call impressive, and they are prone to breaking quite a bit.
Go with whatever you want for the carb. Intakes can be bought/made/whatever. Dellorto or Mikuni would be my top choices, and in fact after the anniversary ride/minirally action here next week, I'm going Mikuni myself.
If you haven't already sunk your hard-earned moneys into that Polini exhaust, I suggest you get an Estoril for Puch and make it fit a Garelli. It can be done.
Hack and weld pipe for the 70 polini.
I have the Polini Country pipe that is made for the angled Garelli exhaust port. Not the best. Go with something else and cut and weld like Quatto and npj suggested.
2nd the Estoril, great pipe for garelli.
derbeez ryderz /
an altered boss isn't bad on a kitted garelli also, never messed with it on a stock set up.
they grow up so fast ....tear.....
thanks for the advice guys....i'll definately do some experimenting
yo mark...when u coming home dood.....u gotta see the cafe seat i made from a harley fender
motomatic makes a nice pipe for the garelli too.
i'll be back to work Thursdays im stoked to see it!!! you didnt get anymore bikes while i was gone did you?
there is also a single ring kit for the noi that is 75cc . i have one its gonna be sick. i really like my malossi kit and my polini is also rad
estoril or a 6p cut and weld or heat and bend slowly with it packed with sand.
i suggest getting an 11 tooth front sprocket if ed has any left.
you'll just have to wait and see
