So I've been working on tuning my peugeot build: polini kit, polini case, simonini exhaust, phbg, polini weights/spring. Recently it suddenly went from running sorta ok but the jetting wasn't right (trying to dial it in), to running really poorly. All I was doing was riding and tweaking the idle screw, I of course turned it back to how it was with no effect. Basically it will idle fine, but once I try to give it gas it will want to die, if I give it enough gas it won't be able to die but it will run really rough. I'd almost say it was "8 stroking," like going a whole bunch of revolutions between firing, much worse than normal 4 stroking, and then firing really hard. I didn't change the jets or needle and it is running way way worse then it was before. Only thing I can guess is condensor or other electrical problem?
