Colin, another thing to do is to loosen your axle bolts til you can easily move your wheel, then have someone squeeze the brakes as hard as they can, then bolt the wheel back down. This locates the drum on the pads' pressure spots as efficiently as possible so you have the most possible pad/drum contact when you pull that lever.
