Re: E50 Magneto Side Seal
Todd rod /
That is problably not your problem, a very small amout of oil around the seals is not abnormal. Seals like that dont need to be broken in they should seal from day one. Are you sure you dont just need to tighten your clutch springs a bit to let the motor spin up a before you start to move. that is what it sounds like to me. What clutch are you using?
