Remove the pedal
put a large crecent wrench on the crank arm
sit on your butt on the ground
brace your feet on the ped
pull hard on the wrench and the arm will bend
a large length of pipe that will slip over the crank arm will also work.
YOu have to pull hard!
Good luck
