What's it take...
Beating those godDamn 150cc chinese scooters
Re: Beating those godDamn 150cc chinese scooters
A+verynice
^^ sickkkk
Destroy All Scooters!
thats my W.I.P. 50cc malossi GR1 AV10
21mm dellorto phbg on custom intake
custom hanging brackets( no weight on the studs)
more to come glad you like it
Re: Destroy All Scooters!
Hey Crack, you think the 21 will be overkill on the 50cc? Looks awesome!
Doesnt take much to beat them top end, or even through the mid range, gettin them off the line takes a good variated bike.
well all four of us got embarrassed tonight by one. thank god my kit came in today, not a moment too soon. will an alukit / high comp head / 4 petal / 24mm mikuni / unrestricted estoril / 20T rear gear be enough?
Tommy is right,
Daul Variator.. best for the win!
Maybe, not off the line. You will need to do some heavy porting to make that mikuni work. It might, but thats a lot of carb for that kit.
i'm racing the fastest m4dasses in the country (that guy that posts on here all the time) sometime this summer, i'm hoping a two speed alukitted tomos will do the trick. i'm not overly concerned.
if it doesn't, it might be time for a polini kit and/or bigger.
Tune the clutch, its all about how high your motor revs up before the clutch grabs. That or pedal harder.
well i'm on a two speed tomos. i'm going to definitely play with clutch spring tension to set the engagement. i'm thinking a really stiff second gear clutch that engages much later. we'll see.
