noob suspension question
I just got a pair of adjustable shocks for my maxi except i dont know how to replace them with the current stock ones. A tool also came with the adjustable shocks, and i don't know what thats for.
can someone help me out here?
Re: noob suspension question
you mean your rear shocks? you just unbolt the old ones from the frame and bolt the ones you bought on to it . . . what's complicated about it? they bolt to the swingarm at the bottom and to the frame, the side rails and each other at the top.
I would blindly speculate that the tool that came with it is for adjusting the pre-load on the shocks, but that's pretty much a stab in the dark.
make sure to loosen up your rear wheel before putting the new shocks on. if they are bigger or smaller it might make a difference in the chain tension.
