i dont know if any 50vs actually have the four-weight variators. i did this on my '62 av88. just wanted to point out that this mod made a tremendous difference, and worked exactly as intended: bike stays in lower "gear" way longer, hits the powerband at a slower speed and remains there longer. combined with the conservative port job i did, this bike now flies like an eagle.
removing 2 out of 4 moby variator weights: success
Re: removing 2 out of 4 moby variator weights: suc
Jay... is that a 78 player in the background? You have the nicest spread of any moped shot I've seen for sure.
yep, old stand-up victrola player. only 47 years older than the av88, and still works like a charm.
my room mate has one of those, it's a wind-up. totally sick. nice moby too, haha.
Jay,
Nice. The best free mod ever for a motobecane.
I found a 50V with a 4 ball variator in it by the way. Other 2 had 3.
i've heard tell of people who have done this with basically no resulting improvement, so i thought i would post my results, which are amazing. if youve got the right tools and know what youre doing, this is about a 20-minute procedure.
The key is to have a strong running engine, and ideally a ported on.
^ on = one
really nice bike!
have done this mod with no success, so maybe you were referring to me. glad it worked for you though.
is the variator on that oldschool moby the same as what were used to with the 70s era 50vs? slap a varplus on there?
ive taken apart one real old variator that mustve come off something like yours and it was a bit different in design then the newer ones.
on a side note i took apart an old av something case (the case the older variator was on) and the transfers were already matched to the transfers on the cylinder. i thought that was kind of a nice touch.
steve -
this variator appeared pretty much identical to the one on my 50v, save, of course, for the plastic piece that holds the weights. i seem to recall a couple other people besides you had also reported a lack of any noticeable change.
my engine case was also already perfectly matched to the cylinder. i was pretty excited to see the nice, pointy transfers on the bottom end. made porting/tuning way easier.
