What performance parts are better for top speed? Tecno circut pipe with high flow air filter, or 70cc k-star with the head (treats for the people kit) with high flow air filter. And this is going on a stock maxi. Thanks
anyone???
You're trying to compare a pipe to a kit. You'll probably gain a few MPH's with either alone. Pipes in general will alter you powerband. Circuit pipes are low end pipes, but you'll gain a few MPH's probably. 70cc k-star will give you all around more power. Ideally, you would get both, and upgrade your carb, and gear out if you are trying to get faster.
Both are better.
First, get a larger 15-16mm carb to go along with a new expansion pipe. Get your bike running good, then Throw a kit.
Tuning your bike takes patience, and money. But, Riding it around at the speed you want will be worth your investment.
I wish I was 13 again...That's when I had my 1st ped.
the kit
