When I was Putting back together my engine, I checked my points. I think the points are at .016-.017mm rather than .015mm.
tried to start it, didn't happen. (plug gap at .8)
pulled it out to test if it was getting spark, it was. Made the gap smaller this time. started up, but running shitting.
So I'm thinking if I advance the timing that will do the trick.
which way do I turn the stator plate to advance the timing on a Tomos A35? Or is there another factor here?
