Hey hey,
if you have a set of Maxi cups from a head set could you give me an O.D. where the cups press into the headtube. I'll be putting some maxi forks on a motobecane, just wondering which cups to keep or which cups to get. wondering if there is any interchange, between the two.
I know the steer tubes are different between the two, wondering abot the head tube I.D or cups O.D. where they are pressed into the head tube.
I'm already certain they are different, I think someone else used the maxi lower race with the motobecane cups and used loose bearings instead of caged bearings like maxis have.
thanks
peace
