puch moped 15mm dellorto question
on the 15mm dellorto carb is there a lever i put on the handle bars for the choke or what?
Re: puch moped 15mm dellorto question
depends on the style, some are cable choke that require a cable and a lever on the bars.
You might want to try using the wiki or maybe even google. People usually dont respond to no brain questions that you should be able to research and find on your own. just sayin
