Random spark?
▣ß@ηℊℙℐṔ∃▣ ™ /
so rebuilt my e50 now when i crank it it has a random spark does not spark all the time some times it could turn over 5-10 without spark. any help?
Re: Random spark?
i have had several coils fuzz out on me. also jiggle the cord.
Re: Random spark?
▣ß@ηℊℙℐṔ∃▣ ™ /
Why would it just go out after a build? just random?
Re: Random spark?
Points or CDI ?
Re: Random spark?
▣ß@ηℊℙℐṔ∃▣ ™ /
points
Re: Random spark?
Every time the primary circuit is open, a spark occurs. Check the entire circuit, make sure that any small insulators used around the points are in place and not damaged. If anything is loose or touching ground, off goes the coil. Check gap and timing too.
Could also be in the kill or ignition switch, but of you have been in the motor I'd check there first.
