Polini E50--no headgasket
Anyone NOT run a headgasket? I have been having issues with mine and I am tempted to deck everything and go without--will it clear a 70cc HC head?
Re: Polini E50--no headgasket
beer can
I have 2 good gaskets, but they still leak.....I was going to try decking the head and cylinder again, but wanted to know how many people are successfully running without the gasket.
I have not been running gaskets since I got it
after and before
its on my alukit e50
) CuperAWESOMO ( /
I don't use head gaskets on any of my bikes. Polish the mating surfaces and use your standard cross pattern when tightening. The 70cc head should clear. I use a 50cc hi hi-comp head and it clears no prob.
do you guys measure your squish clearance? i havnt yet but from what ive read .8mm is good?is that right? what happens if you get to closer than that? or is as close as you can get with out the piston hitting the best?
hot spots and piston failure, usually a hole
ah.....well, im giving the gasket one more chance--found out i soft seized it today but didnt notice. polised the crap out of the surfaces using glass/wet sand so i hope it works out...i'll know in 15 mins.
thank you for all the help!
no good news....now there is an airleak by the exhaust-any way to straighten a warped cylinder?
I didn't then I had a head leak so now I do. I'm sure if I were to follow Tom's advice, I would be leaking, but I didn't and I did, so now I run a gasket and don't leak.
no head gasket 4 me, only copper rtv
I feel like this is a dumb question, but are you using copper rtv for a head gasket?
I use permatex anerobic sealer and no headgasket, never had a problem. (you must have smooth surfaces tho)
you are probably fucking up the decking. hopefully you haven't fucked with your cylinder. you could either have it machined, deck it correctly, or slobber some goo in there.
either that or one of your studs is stripped out or you aren't torquing the head nuts correctly.
that anerobic sealer is cool.
i know all of elliot's bikes rip, so I can't really talk but......
I only use the copper shit to help with exhaust leaks. It says "not for use on surfaces constantly immersed in gas" and something about not using it on cylinder heads right on the tube. I always blow the shit out.
I've had great success with the red permatex anerobic sealer, and the gray "motoseal" stuff that's meant for small motorcycles.
If you get the surfaces properly decked, you really shouldn't need any head gasket though.
I am properly decking the surfaces--this isn't my first rodeo.
Torque sequence is correct--all bolts are torqued properly.
I think it is a warped cylinder...Ever since I put it on, I've had a tiny airleak around the head and possibly the exhaust. I will triple check the decking, re-set the exhaust and clean the head gasket/try without if that fails.
Thanks for all the input!
take a flat edge, not a plastic ruler, but a machined flat metal edge, place it bolt to bolt for each side and check to see if it is flat all the way around, if you can see light under the flat edge then it's not flat. Repeat with head. That will let you know pretty quick.
Yea...I used a tsquare as a flat edge to check, but it was getting late. I'm going to spend some time after class decking everything again and quadruple checking. It's amazing how fast this set-up is even WITH an airleak compared to the Airsal.
You may already be aware but it is the rare pipe header flange mating surface that is flat/level. I use a broad big file and using careful pressure centered over the flange file them
eric the copper rtv doesn't say what not to use it on and it works great on head gaskets and exhuast, don't use it on the intake gaskets r better.
the orange rtv, red rtv, black rtv etc all say not for use around gas but not the copper one.
also works wonders i never get head leaks. but don't use it for other gaskets cuz they will leak
Right-O
that warning is for 4-stroke heads. all goo is fine. i agree with elliot anyhow. copper rtv on my head 4 lyfe.
same here. copper goo is always used on my builds.
Well....the leak was temporarily fixed using copper spray, but that got eaten through and I am now stranded quite some distance from my house. I think the jug is warped pretty bad.....I don't know. I'm stuck and I'm pissed.
So....since I'm stuck here, I took the head off. The gasket is immaculate, minus the gas/oil over everything. I cannot for the life of me figure this out. I'm about to just buy another polini and trash this jug.
!#@@34$##@&**54!!!! Goddamn.
Alright--I'm about to really deck my head/jug (.004").
Anyone have any input before I start to tear this fucker apart? I've got the blood rage behind my eyes and I won't stop until I destroy this thing, or get it tight without any leaks.
don't use goo and gaskets it will leak only one or the other.
also its ur head not the polini that's giving u problems so ur polini is fine.
third how hard are u torquing down ur head and are you doing it in a cross pattern? I've always though 10ft/lbs to be really weak especially for kitted bikes, i always take mine a good bit further but i do it by feel so i can't tell u any exact # but its pretty tight. Probably right b4 a puch stud will snap. (thats a hard feeling to get perfect)
The head is the 70cc HC from treats, previously used on an Airsal kit (which was also decked properly). I go to about 13-15 ft/lbs, in a cross-pattern 1/4 turn at a time. I am using bolts, not studs (ran this set-up previously on the Airsal--no issues at all). I think it is the jug: only because the jug is the only thing that changed from the previous set-up.
I read many times about Polini jug warpage...I was hoping mine was not.
get studs so you don't strip the case. Ask me how I know.
Deck both the head and the jug and be happy?
